Mazda Lowering Static \  need help
need help
views 1311
replies 11
following 5
808mazdawgy   +1y
hey wussup guys i wanted to kno if there is any way to make the back of my ryde better i got 3 inch angled blocks with 3 inch de arched leafs with a rubber slipper in between the axel and frame with toxic drop shocks also but it jus seems theres no travel at all and any small bump i hit it jus bottoms out and sounds and feels pretty nasty any input in appreciated thanks!!
sosatheshark   +1y
install a small 3"notch
dragn37   +1y
you can do a small notch, or if you plan on bagging it, just put a full notch in, but youll have to cut out the bed for the notches until then.. soo ur best bet would to probably install a small notch like sosa said.
crazymikey   +1y
Get a 5" diameter section of pipe and cut it into a C shape. Cut your frame above the axle and weld each half of the C into the frame where you cut. That'll give you an extra 2-3" of travel.
My truck bottoms out if I put a case of beer in the bed. I need a C notch baaaad.
808mazdawgy   +1y
ok so it jus sounds like i need a small notch thanks guys one more question i got drop spindles in the front and they pushed out the wheels couple inches and im runnin 17 inch eskies i like slam the front more but its already rubbin the fender i rolled um too is there anythin els i could do other than cut em out to make it stop rubbin?? thkns
dragn37   +1y
hm thts wierd, cuz i have dropped spindles on my truck, and im also bagged, and i have no clearence issues what so ever.. uhmm other then rolling the lip, im not sure. Maybe you could take the drop spindles out, and try flipping the ball joints :
1hotdawg   +1y
I'll take your spindles if you decide to remove'm!
dragn37   +1y
hotdawg: im actually going to sell my spindles soon, PM me
808mazdawgy   +1y
yeah its weird maybe its the spindles i got i bought um brand new but couple of my other frens had spindles that didnt push out there wheels so im kinda confused but i sure love the smooth ryde in the front haha
crazymikey   +1y
I had spindles with Eskies and they rubbed. I cut my fender lip out, but also ran 4x4 fenders. Rubbed at full lock after that.
