Mazda Lowering Static \  NEED HELP!! Pathie rearend ?S
views 1269
replies 12
following 6
ticky   +1y
hey guys. anyone know how much narrower the rearend is on a pathfinder and which year range should i look for. not concerned bout disc brakes. getting ready to bag the rear on my 89 B2200. got some 18 nissan titan wheels and they will rib when i drop it. thanks for any info!!
elbine69   +1y
Its about 2" narrower than the mazda axle. Youll want to look for one from the first generation pathfinders, because the newer ones are wider.
ticky   +1y
THANKS!!
idropdit (brandon)   +1y
they also have stock 5 links on them. not sure if it'd work for your application, but it's a decent link setup from what i've seen. i have a couple of the axles and links lying around here.. the disc brakes are also a plus. try to get one from a pre-95 pathy.
ricksb2200   +1y
are those rear ends 6 or 5 lug?
they're 6 lug.
ticky   +1y
the pre95s have disc too? didnt think they would be back that far. any idea on gear ratios. also im putting a v8 in the truck. should i get a 4wd rearend? im assuming it would be stronger...
elbine69   +1y
Yeah the pre 95s have discs. Couldnt find any info on gear ratios but there are aftermarket gears available so you could always regear it.
ticky   +1y
i found a 95 with disc. is this included in "pre-95"? might sound like a stupid question i just dont want to spend the money if its not worth it.
ticky   +1y
hey guys. i went to the salvage yard today. i measured a 95 with disc brakes and a 93 with drum. both seem to be the same width as my rearend. i measured from the wheel mounting surface of the drum/rotor and from the backing plate and they all seem to measure the same. help me out here guys. the rearend is whats holding me up!
