Mazda Lowering Static \  layin frame in the front?
views 1026
replies 8
following 7
bjv7022   +1y
i recently bagged the front and in the process of baggin the back.
im runnin 215/45R17s. i flipped ma lower balljoints and still have about an 1 3/4in to lay frame in the front. i was told i didn't have to pie cut the uppers. should i get drop spindles? or what to do?
also i have alot of camber. will cutting the uppers help this?
sleepyspeed   +1y
you have some cutting to do somewhere, have you made sure the lower clears the frame enough to allow it to go high enough? Otherwise you just have ball joint bind and it's time to cut the uppers.
post pics of your front up and we can help you out better.
bigamigo   +1y
also dont forget you have to lose the inner fenders also and if youre trying to lay out move the crossmember up 3/4" to lay even imrunning the same size hela alot of cutting
sparage   +1y
Are your bags bottoming out?
bjv7022   +1y
i checked the lowers. they clear the frame.
i guess i will have to cut the uppers. the ball joints are binding up. ill try to get pics up. busy finishing the back.
bigamigo   +1y
post a pic we can help you better i cut my lowers a lot and also flipped my bjoints but just the lower and i tuck 2" of the wheel whenn layed out no bd yet
toddluck   +1y
also flip your upper bj for about another 1/2 inch
flameds10(tyler)   +1y
that would be my guess
you can also try spacing your lower balljoints up
speedster93b   +1y
keep in mind: spacing the lower ball joint won't help if the upper is binding.
