Mazda Lowering Static \  Bar Lengths Need help.
views 794
replies 7
following 6
lsb2200   +1y
I am going to order a triangulated superlift super pivot 4link soon. Can anyone give me an idea how long the bars need to be. Any help would be appreciated. Thanks
slammedxonair   +1y
If your interested in a 4 link kit, drop me an email to and I can take care of you.
h2omelon(nick)   +1y
I'm assuming it is the standard cab in your garage pic.If so I would run 30" center to center lower bars.The longer the bar the les fore and aft movement you will have during the travel of the suspension.With a short bar your axle will move forward quite a bit when laid out due to a smaller arc.The longer bars will help keep your wheels centered in the wheel wells when laid out.
lofosho86   +1y
what about lengths for an ext cab?top and bottom!thinking about making a wishbone for the top
h2omelon(nick)   +1y
I am using 28" bars on my 90 ext cab. The bars start at the back of the cab.It's a tight fit but worth it.
lofosho86   +1y
cool thanks Nick!
speedster93b   +1y
the lowers on my std cab are 34" pivot to pivot
the uppers are about 36 1/4"
they both mount to a crossmember i built that is welded in place, approximately where the front bed mounts are located
ticky   +1y
man that is clean!!
