Mazda Lowering Static \  indexing torsions affect ride quality?
views 1062
replies 8
following 6
slamdtaco   +1y
I know the ride gets worse when lowering by turning torsions and the lower you go. if you index the torsions 2-3 splines then turn the torsions for a 4-5" drop how bad would the ride be assuming you removed bump stops and had good/shorter shocks?
in other words is it necessary to get spindles to lower 4-5" and still have a good ride?
crazymikey   +1y
It actually gets better
staticb2200   +1y
I got my mazda down about 5-6 inches and the ride sucks lol. That is with me reindexing the tortions i think i did 4 splines. At about 4-5 inches using the isuzu pup shocks you are maxed out and there is no room for travel in the suspension and that is where I am at now. So I am looking for spindles now because that will give me about 2 more inches of travel. Hope this helps.
toddluck   +1y
the only thing it does is move the brackest up so they dont drag it may softer the ride (very little ) because you get the bars as tight as they were (spring rate thing ) but it isnt going to be noticable because you will bottom b4 spring rate goes into effect
crazymikey   +1y
Mine's pretty damn bouncy, but I also have stock shocks and still have my lower bumpstop brackets.
If you get spindles you need to run a 16" or bigger wheel for them to clear, and they also make the wheels sit out a little further, so you may encounter rubbing problems as I did with my Escalades.
However, your truck is lowered so it's going to ride like shit no matter what. You want a cushy ride, buy a Cadillac.
noridetoolow   +1y
I have been suprised at how WELL Mazda actually ride when slammed out...the ony problems arise from lack of clearance and shock length. BUT...if you wanna slam out a Mazda...GOTTA remove the bump stops! Otherwise BOUNCY as crap!
Of course.....another great reason is so that you dont wanna snatch off your torsions! I have done that a few times, lol
slamdtaco   +1y
I will reindex the torsions, flip b/j, cutout bump stop, toxic shocks, c-notch rear, remove leaves, 3" block, and better shocks and hopefully will be the ride I'm looking for.
I already got my chrome escalades on with 215/45s and a 4" front drop would sit right on top of the tire
not true....
I bought this new in 90
this pic was around 92 and it rode like a cadillac
spindles, torsions, tokiko shocks, front and rear sway bars
2-3" ground clearance
my 95 tacoma somewhere around 99-00
on 18s with about a 6" drop
toxic shocks
also rode like a cadillac
tunameltman   +1y
Well mine are indexed like 3 or 4 splines, can't really remember, but my front rides amazing, its the rear that kills it, monoed with overload and 3 inch blocks. I will have to post pics of how low my truck is now, I've taken them, just haven't uploaded yet, but it's hella low, and rides really good.
tunameltman   +1y
OK here's how I'm sittin right now, like I said 3 or 4 splines, and rides like a dream, and I still have about 2 or 3 inches to the bumpstop brackets, and they barely ever bottom out, but still gonna cut em one day, lol
