Mazda Lowering Static \  toyota 5 lug swap
toyota 5 lug swap
views 1149
replies 8
sicsic6   +1y
i have an 84 toyota 2wd. does anyone know how they do the 5 lug swap to the mazda with these parts?
paparoach1983   +1y
I think they get the spindles and fit the ball joints some how to them then use a yota rear end. if i am wrong i know some one will correct me. lol
sicsic6   +1y
bump. need help. moving to arizona and dont wanna waste this 5 lug swap if i can use it.
thebeaumartin   +1y
ok well now you make me feel like an ass for telling how to do it haha well im an ass so here goes.
1. remove the mazda ball joints weld up the holes from the bolts and drill the large hole bigger to fit the toyota ball joints.
2. mark the new holes on the control arm and drill them then bolt them in and the bolt up everything else.
3. the brake line will work on the new rotor bolt that up and bleed.
4. tierod ends i cut mine and welded the mazda and the toyota ones together then drilled a hole through the tierod end and bolted it up just incase the weld was to break.
5. you will have to swap the rearend run the brake lines and bleed and have a drive shaft made its cheap mine was 90.00 and its done.
thebeaumartin   +1y
the whole deal takes around 8 hrs to do its easy and fun and looks killer i had pics from when i did mine posted i dont know if there still there i will look for you
paparoach1983   +1y
DAM i may just need to do this. lol
thebeaumartin   +1y
i loved the way mine looked.
thebeaumartin   +1y
here is the link to my photobucket
sicsic6   +1y
sweet, thanks. i'll see what i can do!
