Mazda Lowering Static \  compressor
compressor
views 704
replies 4
gsmazda   +1y
Ok does anyone know of a quick fix my compressor runs on and off throught the day and night and it kills my battery the only way to stop it is to disconnect the fuse from the power wire I know I need a different pressure switch but I need a temporary fix until I can order one is it ok to just run a kill switch to it if so what would be the best way to do so
90-b22dawg [andrew]   +1y
you could run your main power for the relay off a switched + source... you are running a relay right and not depending on the pressure switch to turn the comp on and off?
gsmazda   +1y
Honestly man im not 100% sure I had my buddy finish my back half I've been out of commision with surgery I had a relay with everything I gave him he just told me I needed a dif pressure switch I haven't been able to really get out and look at the truck in about a month I just figured I could cut the fuse of run a straight power wire to a kill switch before the comp.
bgdb26k   +1y
yeah, needs to be hooked up to a keyed source man!
elbine69   +1y
^What he said. Or at the very least a toggle switch, so you can kill the power to the relay when the trucks off.
