i have a set never used them was told they bend easy
demonek
I'm just curious since I'm not a very experienced welder and I'm nervous about getting the front right because I don't want to be popping bags n such...figure the more bolt-on stuff I can find the better.
sleepyspeed
I can only offer that these will not let you lay out, unless your using a very small diameter wheel tire combo, like a low pro 14". I have seen a truck in person that had these with 18" and it was a good 2 - 2 1/2" off the ground when laid out.
elbine69
Like he said they will not let you lay out unless you have a very small rim and tire combo. Also depending on what bag you use, the brackets will rub on the bag. We took some off frocashmoney24's truck, and the bags were almost rubbed through in a few different spots. Heres a picture before it was taken off:
demonek
Sounding like I should put on my big boy panties and start welding huh? haha
toddzda
Wow didnt know they made bolt on kits.
90-b22dawg [andrew]
wow....
slammedmazda
There junk! Like sleepy said, They don't let you lay out all the way. I have the same brackets and im (was)running 16' and i was a good 2in from laying out all the way up front.
