air ride wiring ?
air ride wiring ?
j$c
I'm looking for an ignition source to connnect my pressure switch to... Could somebody tell me what wires yall are using, and maybe the color so i can get this thing connected...
midnightmike's avatar
midnightmike
according to bulldog securitys site
you can use the black/white stripe wire, in the steering coulmn
hope that helps
if you got more questions let me know
all22s
if you remove the shroud around your steering column (3-4 philips head screws) then you will see the actual ignition switch on the left side of the steering wheel. if you look closely at the switch where the soldered ends are... you will see each wire labled (bat, ign 1, acc, starter etc.)
or just get a dmm (digital multimeter) or test light and probe each of the bigger gauged wires to see which wire is hot (has voltage) only when the key is turned to run.
i know this isn't telling you the exact wire but it is showing you how to find it. btw don't use a test light to probe wires on newer vehicles FYI.
j$c
thanks guys...i was jus looking around the fuse box, on my honda it has an extra couple of hots already connected and i jus used a female connector and ran it...
am goin to get take the steering column cover off now.
thanks
90-b22dawg [andrew]'s avatar
90-b22dawg [andrew]
you are using a relay for the comps?
j$c
yes i am
