Mazda Lowering Static \  need help! want to bag without cutting too much frame
views 785
replies 5
91hotboxx   +1y
hi i was wondering wich is the best way about baggin without having to got too much frame i still wna ride around with my 14's on the lowpros but its kind of impossible to do so in newjersey on as low as i am now at static so any input wud b helpful thanx
crazymikey   +1y
you don't have to cut any of your frame except for a notch in the rear for your axle which is easy.
Otherwise, the only cutting and fab you'll have to do will be with the suspension components themselves.
Or I could suggest a 2" c-notch in the rear and install air shocks all around. it's kinda like being semi-bagged in a super ghetto kind of way.
91hotboxx   +1y
hahaha i actually thought about doin the airshocks but then realized how much a pain in the ass it would be. would i b able to run a 4 link with a 2inch c-notch?
90-b22dawg [andrew]   +1y
to much of a pain to do air shocks? its alot more work to install a 4 link and bags............ but if your going to do it you are going to have to cut the frame a bit. search through the Project / Under Construction thread for bagged trucks.. alot of good info. there......
crazymikey   +1y
Air shocks aren't going to net you much improvement over your static drop. If you do air shocks, you're basically half way to bagging it, so you may as well go all in and bag it. You don't have to get into crazy stuff like bodydrops or anything.
If I were ever to bag a truck, simplicity and function would be my main priorities, rather than having a crazy setup with fancy stuff.
speedster93b   +1y
yes
