grant steering wheels
9
93zuzu89
i found a couple of grant steering wheels at my local advanced auto parts and i was wondering, what kind of adapter would i have to get to get one of those to fit in my truck? and how do you go about takin the stock steering wheel off?
lethalethan
To get the stock steering wheel off you have to take out the horn button. You can pry it off with a screwdriver. Then you take off the nut in the center of the wheel and pull the wheel off. You may have to hit it a couple times from the back to jerk it loose so you can slide it off of the steering shaft. Or you could also rent a steering wheel puller from the auto parts store. Im not sure which grant adapter you need. The auto parts store should be able to tell you which one to get. I have an ebay wheel in my truck with a hub and quick release. Its pretty nice for ebay.
eatinpavement's avatar
eatinpavement
if i remember right it is grant installation kit number 4509. it used to be 3509 but they changed it a little. so either should work.
9
93zuzu89
thanks guys.
Related Discussions in Audio / Interior
fiberglass
I
last post by ityler +1y
4
