toyota rearend????
toyota rearend????
lomazda87
if i got a toyota rearend what mods would have to be done to make it work on my mazda? any driveshaft mods or anything?
paparoach1983's avatar
paparoach1983
NOT SURE but i do beleive this has been talked about on another topic
lomazda87
i cant find anything
badchicn (rick)'s avatar
badchicn (rick)
Yeah, you need to take your drive shaft and add the Toyota end to it. I took mine to a driveline shop because I wanted the length to be correct. Also, this is not a bolt in, which is fine if you are doing a four-link anyway. What I mean is, if you intend to use the stock rear leaf spring, you will need to modify the mounts on the stock Toyota rear to fit.
