Mazda Lowering Static \  Removing mounting bracket from SMC valves
views 668
replies 2
following 2
skrapinsask   +1y
Well I'm mounting my valves and the little silver bracket that comes on them is in the way plus i wont be using it so how do i removed the mounting bracket? i see there is a clip that slides off the very top of the valve does this remove the black plastic housing from the metal in order to remove the bracket?
thanks in advance guys
dzminiz   +1y
I believe the clip comes off, then solenoid slides up, and the bracket has the 4 screws holding it on, also.
skrapinsask   +1y
Yes there is 4 little allen screws
i didn't want to pull the clips off unless i knew what i was getting into
Ill give that a try
thanks!
