Mazda Lowering Static \  Suspension Setup Information
views 1670
replies 17
following 7
mazdadropped   +1y
OK so i have ordered almost all the parts i need(i think)
I Have or soon will have the following :
Switch box
Compressors(2)
Tanks (2)
Fitting
Valves(8)
Airlines
Air gauges
Bags
Bag Brackets
Dump&Fill Control (1 of each)
4 link(superlift??)
shocks
am i missing anything ??i know i dont need a check valve, i read that if i have 8 valves(1 position each) i would need 4 dump and 4 fill controls
also is a do i need a watertrap (if so do i need a drain port to)
what about a oil trap(inline oiler) BTW: i got 2 480c Viair compressors
Post was last edited on Mar 12, 2010 05:03. This post has been edited 1 times.
vrtclychlngdb22   +1y
JW why you are gonna use air shocks on a bag set up...
mazdadropped   +1y
i meant shock not air shock lol
baddawg253   +1y
why two tanks? how big r they ? what kind of compressors?
mazdadropped   +1y
two 3 gallon 31/2"port tanks with 2 480 viair compressors
baddawg253   +1y
thats a good set up then, i have a 5 gal and two 480s its quick
mazdaman82   +1y
i had one 5gal and two viair 380c's and it was great.....all you got is one more gal then i had...it will do you good,... you can play some but not to much.. but like you said its fast so you dont have to wait long
mazdadropped   +1y
Nice but from the list of parts i have am i good or do i need a water&oil trap with a drain port thats my main concern
elbine69   +1y
You should have a water trap after the compressors. You don't need an inline oiler. You should have a check valve, but I believe that the leader hoses on the compressors have one built in. And you will need one fill control for each valve.
paparoach1983   +1y
AND DUMP CONTROLS FOR EACH VALVE
