1newmaz
I am in the process of slammin the mazda, I was wonderin how much drop you can actually get from the torsions, and removin the leafsprings(already have 3"blocks on it). And i just bought a notch and bridge kit with bag brackets for when I do bag it, could I go ahead and put the notch on, if I can how much more drop could that give me if any? Thanks guys sorry for all the dumb questions.
paparoach1983's avatar
paparoach1983
well the notch just makes you have more clearence for your axle to move up and down search static drops in the search function there is a topic that ppl are posting pics and the tell you what they are running or have done. and i would say just put the notch on and go with it bro
snoplow
the notch will give you all the room you need in the rear
baddawg253's avatar
baddawg253
ya roach is right you just wont be bangin your rear end if you do the noctch now, also be carefull when doing the front. dont run the bolts almost all the way out you could loose a tortion bar (my buddy lost one on the freeway!) lol ...also make sure your truck is up off the ground when loosing the torion bars! another buddy of mine almost lost his fingers!
lowridenmazda
I pulled my bump stops out and removed my torsion bars and I was tucking about 3/4 of an inch of a 205 50 15.
xjoewhitex's avatar
xjoewhitex
Why did you remove them? You can get just as low with them, and still have have suspension.
8
88ext22
^^^ Agreed Ive still got my bars hooked and im tuckin just about 1/4 inch on my 14's ha ha
