Mazda Lowering Static \  brake proportioning valve
views 1166
replies 4
following 2
justmeandmymazda   +1y
Ok I am not sure if this belongs in here but if not I understand.I am getting ready to notch and bridge the rear of my truck.My qeustion is the proportioning valve the rear brake hook to is right where you gotta cut any of you guys have to move it when you did your set ups and where did you relocate it just wondering and looking for suggestions thanks in advance for any replys I may get
nobody ?
bump
nc4life   +1y
Everyone I did I just moved it. I would unbolt it. Do the notch and all the other work. And then find a suitable place for it. If you need to you can just replace the line that comes out to go to the rear and make it longer. That way you can mount the plate where it turns in to the rubber line closer to the rear so you have room for that to flex. Hope that makes sense.
Makes plenty of sense to me thanks for the reply I was wondering if you could remove it all together and just t the lines on it to the rubber line or if you actually need it for the brakes to work properly
