Front suspension torque specs?
taylor_ash_45@hotmail.com's avatar
skrapinsask's avatar
skrapinsask
just refurbishing my front end and getting it all back together. Specifically looking for the torque spec for the wheel hub nut but the whole front end would be great! thanks
itslikewhooa's avatar
itslikewhooa
upper ball joint to steering knuckle (86 and later) 22 to 38 ft lbs
upper ball joint to upper arm 14 to 20 ft lbs
lower ball joint to steering knuckle (86 and later) 87 to 116 ft lbs
lower ball joint to lower arm 60 to 70 lbs
upper arm pivot shaft to frame (2wd) 54 to 68 lbs
lower arm pivot bolt 87 to 116
and as far as I've ever been told the hub bolt should only be finger tight.... just enough so the hub doesn't move in or out on the spindle, but only finger tight.... to tight will cause over wear on the bearings and shorten there life a lot, never mind heat things up so much you could ruin your hubs
hope this helps
skrapinsask
That helps! just working on getting it all re assembled and waiting for my wire wheel adapters so i can set it all up before starting the rear
thanks!
itslikewhooa
nice... ill have pics of my rear setup later tonight.. i got the 4 link all mocked up yesterday:)
