Mazda Lowering Static \  Lift Issue, Viagra wont help this one
views 624
replies 2
following 2
lsonboost   +1y
Alright so I have the bridge and rear bags in I ended up going 8 inches total including frame. Now my problem is It will lay just fine with a 1" board under each rear wheel (Z71s on a 195/50 and plan on going 18s with a 35 or 40 series tire" with roughly 2" between axle and frame. When its layed out i can take the bag out and compress it another inch so my question is do I move the notches down another inch and thats all the better it will lift or is there something else I can do. Running dominator 2600's in the rear bag over axle total notch is 8" please help!!
laidmazda   +1y
i had the same problem on my chevy since it was bagged for 24s but only ran 20s all i did was make a 2 inch spacer kinda like a bag cup and put it between the bottom of the bag and the mount and used a bolt to bolt it in works fine and has aliitle more lift
lsonboost   +1y
Ok thanks yeah that was my other option in case i ever ran a bigger wheel. Thanks for the info though Ill probably run a 1" and then plates just enough to bottom the bag out and lay frame at the same time.
