Mazda Lowering Static \  toyota 5 lug conversion
views 2026
replies 4
totaloss83   +1y
I have an 86 excab Mazz,. I also have early 90's Toyota hubs and spindles.I want to swap it over to Toyota 5 lug. Does anyone know what has to be done to fit toyota hubs or spindles to the mazz?
laidmazda   +1y
i tried that needed to get the toyota lower ball joint and the outer tie rod end and a way to connect the tie rod to the mazda steering, i found it to be easier to just get redrilled hubs
totaloss83   +1y
my 92 b2200 has redrilled hubs, but i want to go a different route if i can. i know it can be done. i jus want to find out how, and what i need.
laidmazda   +1y
yea it can be done you just have to drill the control arms so the toyota balljoint will bolt up and find a way to hook up the tie rod, ive heard of some ppl making an adapter but havent done it myself
90-b22dawg [andrew]   +1y
theres quite a bit of builds here that have a good bit of detail on how to do the swap. wish i could point you to a page that has the info. just got to take the time and go through the build threads.
