Mazda Lowering Static \  Brake booster ?
Brake booster ?
views 898
replies 5
lowridenmazda   +1y
I know that running 20's with a decent tire you run into a problem with the brake booster. What brake boosters can I get that I can bolt right in and work?
nc4life   +1y
In your other post you said you are running a 243/35 20 right? None that I know of that bolt right in and work. So guys use the brake booster out of a geo metro and some guys use a manual brake out of a older chevy. But with that size tire it's going to have to be moved over some. I haven't gotten that far yet but I plan on using a manual brake out of 70's chevelle.
mazdaman82   +1y
i used the booster out of a pre...it bolted in and stoped the truck fine...it was 2" smaller then mine and had a remote tank
lowridenmazda   +1y
I've been tossing the idea around of running a 245 30 in the front to help with some of these problems lol. I read about the geo metro one but I could find a year.
toddluck   +1y
Het ahold of tuckin20\'s tavis project strech he has the best set up ive seen so far
lowridenmazda   +1y
looks like he is running the stock brake booster? Im doing a 318 swap so i don't need the clutch master cylinder. i guess i just need to bolt my wheels on and start cutting till i hit something i need lol.
