control arms
control arms
9
93mazda
So im new to bscene and new to mazdas(had a hardbody back in the day, now a gmc jimmys my daily) ive got a 93 b2200 that im in the process of bagging and was wonderin if anyones tried to triangleulated the lower control arms to get rid of the strut rods? i cant afford the aftermarkert ones that cando sells....just trying to get ideas
Go to twisted minis.com seth has a pretty good write up on there if I remember right
paparoach1983's avatar
paparoach1983
I THINK A COOUPLE PPL HAVE DONE THEM .
There's a lot of people who have done this. This is from my Toyota but the procedure is pretty much identical. My project thread -->
Basically what I did was I made an alignment tool using nuts from the strut rod, longer bushing bolt, and metal sleeve to center the bushing for triangulating the control arm. Here is a pic of the tool. I had to cut it off and realign it to do the other side.
Now I could have used tubing but I'm perhaps a little ocd and wanted the added part to match the control arm.
9
93mazda
where did you mount them on the frame and it looks like they would hit the frame laid out maybe just the pic angle
mazdalowandslow's avatar
mazdalowandslow
From the photos it looks like the control arm is already compressed.
From the photos it looks like the control arm is already compressed. He has about 2-3 inchs for bag placement.
lol guys I wouldn't do all of that work and not have it lay out
More pics in my thread -> click here
These were for ideas, also note my truck has been z'd in the front but I'm sure you know to check for clearance with your wheel tire combo for how ever you decide to triangulate. As far as I know Mazda's do not need to be z'd to lay flat frame.
I will get more pics in my thread after I finish my rack & pinion swap, 5psd conversion, and have the frame in primer. These are just pics of everything tack welded from the mock up.
elbine69's avatar
elbine69
I like how you did your control arms baha. Looks great and like it came that way from the factory.
Thank you sir
