1990 b2200 lowering front
krunkelton
might have been posted before (noob here)but what the best way to lower the front end i just want about 2-3 inches.
i hear you can cranks the torsion bars but to much it can break the heads off the bolts also i hear you can take something off and move it a tooth over (not sure what it is super brain fart right now).
or just buy a kit right now im trying to make my truck a super cheap build so just like some info on all this from the lowered mazdas
its called reindexing the torsion bars
just loosen the tbar bolts and it drops ...make sure you jack the truck up so the tire is off the ground or youll loose a hand
krunkelton
awesome haha but does it change tire wear and all that ??? my uncle owns a shop so i can use his lift. so basically i just loosen the bolts and it drops it a few inches to i leave bolts loose..?? or i drop it and move it a tooth or whatever?
you can respline it it helps keep the bracket from dragging just loosen i think for every inch on the bolt you loosen it drops the front 2 inches
to respline remove the bolt knock out the bar from control arm move the bracket up toword the cab and reinstall
it make take a few time messing with the tbar bolt to make the truck even
krunkelton
thanks make more sence to my idiocy now
