Question about airbag set up
otterboy47@yahoo.com's avatar
otterboy47's avatar
otterboy47
I have just scored a set of 3 inch drop control arms. Question is has anyone used them with there front air bag set up? Can it be done. I'm a bit new to this. Any help out there?
Chances are yes lol do you have any pictures of the arms? What are the specifications of the arms like what brand are they? Are they custom built?
As far as being able to use them with air bags the answer is yes but depending on the brand more work may be required, and a lot depends on how close to the ground you want it to lay.
otterboy47's avatar
otterboy47
The arms are from DJM
You're just going to have to remove the shock mount to weld the lower bag bracket on, that's all I can see from the picture.
otterboy47's avatar
otterboy47
Sweet. Thanks for the help.
V
v8mazda4ever
Ya you also have to watch the spacing of the bag to the mounting of the ball joint as it is raised up on the drop control arms and the angle of the arm just makes it abit more work. You will also have to remove the sway bar mount as well.
otterboy47's avatar
otterboy47
Cool. I cut all the sway bar and shock mounts off. I got my buddy in on the rest. He should a damn NASA engineer. lol! So I think we should be okay. Thanks for the input guys.
