Mazda Lowering Static \  Rear-end swap / driveshaft question.
views 716
replies 3
stlowburban   +1y
So I'm bagging a 91 extended cab for a buddy on Tahoe wheels and we swapped to a 84 rear-end since it's narrower. When I got the rear-end I got the end off the 84 shaft as well but the 84 shaft is alot bigger in diameter than the 91's so I cant just get hte 84 end put in the 91 shaft. First thought was to make a plate with both patterns on it to go between the 91 shaft and the 84 snout, but (Finally, here's the damn question,) does anybody know if I can put the 91's snout on the 84 differential? Anybody done it? They both come off but are the splines the same? Thought I'd ask before I wasted an hour or so pulling them only for it not to work.
beatmymini   +1y
I'm curious to find out as well. does the old rx7 lsd snout fit in the pre housing?
bagdb2200   +1y
I put a Toy rear end in my truck, and the Toy driveshaft is smaller diameter also. I took it to a driveline shop and he just made a new driveline with my 700r4 input on one side, and the Toy diff end on the other.
stlowburban   +1y
That's what we usually do but if the ends will just swap I won't need to. Bump for the afternoon crowd.
