**Need Help Quick!!**
bmxdad45@yahoo.com's avatar
88mazdab2200's avatar
88mazdab2200
I am right in the middle of my first static drop....I took the torsion bar off on the passenger side and turned it three clicks and bolted it back to the a-arm (finger tight). The back bolt won't come anywhere close to the "nut" on top in the cross member. Is this normal?
jimbeater's avatar
jimbeater
meaning you havent got a lot of thread into the 'nut'? have you put it back down to see what ride height is at now?
if you dont think it has much of the bolt threading into the nut, then i would probably re-index it back one.
chilnviln's avatar
chilnviln
use a jack to help lift the back end of the torsion bar so you can thread the bolt back on.
88mazdab2200
Haha I got it!! I was lifting it! If you turn the torsion bars the right way it helps.
