Mazda Lowering Static \  long ramble, simple ?
views 828
replies 6
following 5
drpdwgn   +1y
I just got a 92 b2200 ext cab and want to keep it static drop only this time. My last static drop I had was a 86 b2000 standard cab with mono leaf/3"block and crancked torsion bars. I liked the stance of that....but want maybe even lower this time. My ? is.....I want to still be able to load up my motorcycle in the back. 2008 suzuki m109r. I plan to re index torsions, smaller shocks and bumpstops removed up front. For the rear i found some monroe shocks that have overload springs coiled around the outside rated to help with loads up to 1200lbs. I wanted to do those with a 3" or 4" block and would like to keep as many leafs as possible. I know just a 4" wont get me where i want to be, but has any one done any 3"or 4" combo with 1 leaf out?? if so, which leaf?? Any insight would be appreciated....thanks. Also i will be running escalade 17's, not sure the size of tire yet....any ideas??
baggedbmy93mazda   +1y
there is thread somewhere on here....called mono leaf. i think its this forum.
search for it and you will find alot of info and pics that can give you an idea of about how low it will sit. this place is full of info just have to search for it sometime...
good luck.
this should help...but yeah just search.
toddluck   +1y
No matter what you do if you load the bike up with 4 inch blocks even without removeing springs your gonna hit axle to frame id spend my $ on air shocks!..not the coil overs
bagdb2200   +1y
Word, mine hits frame on some bumps with nothing in the back and only 3" blocks.
drpdwgn   +1y
thanks for the input so far......i forgot to add that i have a mini notch in the rear.
shavedmazda   +1y
Something like this kit might work for you, or a kit like it that is more universal? It is what I am using on my 08 tacoma daily that is hammered with a 3/4 drop and 22's... I can haul my bike in the back... also you could always install a mini C notch and it wouldnt affect the bed... just a few thoughts for ya
