Mazda Lowering Static \  can i put 4in blocks with all my leafs in
views 1158
replies 9
following 5
cvillen17   +1y
i want to go lower but i need to carry weight sometimes
i have air shocks with 3in blocks in the back can i go 4in blocks with it
those it have to be regular blocks or angle blocks
pleaase help i need to kill the fender gap thanks
toddluck   +1y
yeah but you will hit the frame with any weight
johnnydigits   +1y
install a mini notch so you dont hit the frame.
1hotdawg   +1y
I could be wrong, but I don't think you're going to hit frame by adding 4" blocks and keeping ALL your leaves in. I think the other guys above missed that part
toddluck   +1y
still gonna hit cause he is putting weight in it
cvillen17   +1y
do i have to get angle blocks or regular blocks
thanks
toddluck   +1y
With 4 inch yes go with angled or your pinion angle will be way off and your chew up ujoints much fasyer
toddluck   +1y
With 4 inch yes go with angled or your pinion angle will be way off and your chew up ujoints much faster
88mazdab2200   +1y
Angled. I have 3" blocks with one leaf removed and I haul 2 full size dirtbikes in mine all the time. I left the bump stops in and did not cut them. It's not quite as low as I would like, but you gotta sacrafice somewhere, right?
cvillen17   +1y
ok thanks for all the help i just order my 4in blocks
