help with bad camber
mazdawg22@yahoo.com's avatar
dropn-mazdawgs's avatar
dropn-mazdawgs
i have a ? wats the best way to some wat fix the camber on my lowered mazda b2200
Remove or add shims to the upper control arm mount. Do you have negative or positive camber? Do you have a picture?
dropn-mazdawgs
its lowered and its negative camber i took all the shims out n that didnt even budge
dropn-mazdawgs
dropn-mazdawgs
chilnviln's avatar
chilnviln
if you took out all the shims then there's not much you're going to be able to do aside from longer UCAs , balljoint spacers (do they make a universal one?). drop spindles may help some but to what point do you want camber fixed? back to 0
1hotdawg's avatar
1hotdawg
How much camber is too much for you? Most static drops are going to leave you with some neg camber. You can flip the lower BJ and that may help a little but is no miracle cure. I've got camber and just had the alignment done, so it isn't getting fixed without some lowered arms or something. It's not enough to eat up the tires I don't think...which is usually an issue with toe moreso than camber.
dropn-mazdawgs
i got alot there wearing inside really bad i just wanna get rid of some of it or all i know you cant get all gone just some lol if you guys want you can txt me 208-262-1480 just let me kknow who you r
oneslammedbseries
the drop spindles on my mini made a huge differenc and there gonna help lay the 22s alot to probably a good investment for the mini before you bag it man
dropn-mazdawgs
K thank you
