Lowering questions
Lowering questions
ace
Whats up guys, Im new on the board. First post! Ok so I bought an 87' B2000 ex cab that was allready lowered. The guy I bought it from said he reindexted the torsion bars up front and removed 2 leafs and 3 inch blocks! It rode pretty well when I got it but I noticed one of the front shocks was blown out and that side would rub every once and a while, so I thought new shocks were the answer. It had some ac delco's on it but I couldnt find a part # on them, so I did a little research to find the shortest shock I could, being a Monroe 37016 which was an inch shorter than the ac delco's that were on it! Now the ride is rougher than before but I don't rub fender anymore but I think that is because the shock actually raised the truck about a half inch! So finally my question is this, if I were to flip ball joints to lower it an inch and reindext one tooth to raise it up a little wouldnt in theory I have more shock travel and a better ride??? If so how much will reindexting one tooth raise it??? I know the monroe($30) prob wasn't the best choice but thats all I could afford for now, I'd like to get doetsch nitro's eventually! Trying to make the best of what I have for the time being! Any advice would be greatly appreciated!!! Thanks in advance!!!
ACE
tucknrimmaz's avatar
tucknrimmaz
Flip the ball joints and just tighten the torsion bolts a lil if you have the room. If not you will have to reindex to get the lift you need. You are indeed correct about that giving you more shock travel.
ace
Thanks man!
