Mazda Lowering Static \  driveshaft hitting frame
views 1109
replies 4
following 2
ah_c?mon   +1y
I got a 91 b2200 and I I've had a 3inch angle block with one pulled leaf in the rear....but today I decided I wanted to go lower so I pulled another leaf so now I only have the bottom and the one that bolts in. but now my frame sits on the driveshaft so I can't drive any where. can anyone help me figure out to fix this? any info would be deeply appreciated
kovz   +1y
Your frame sits on your driveshaft? What?
You mean a crossmember is hitting your driveshaft?
Do you have a single piece or two piece driveshaft?
My best suggestion would be to raise it back up or notch the crossmember.
ah_c?mon   +1y
it hits the cross member right where the cab Andre bed meet
kovz   +1y
That makes more sense. Im assuming you have a single piece driveshaft, otherwise there would be a carrier bearing there so it would not hit.
Can you cut out part of the crossmember to notch it? Or look for a 2 piece driveshaft.
ah_c?mon   +1y
I had my friend look at it and he said that he had 4 inch angled blocks with one pulled leaf and he never had this problem...he also said that his block had a bigger angle then mine. could I put those alignment shims or put a block with a bigger angle?
