Mazda Lowering Static \  help finding lowering kit for 01 b3000?
views 756
replies 5
01/b3k   +1y
i have a 2001 b3000 2wd xcab i wanting to lower it about 2-3 inches but i cant find a full kit does anybody have any ideas? or a know where i can find a kit. it has factory 2 inch blocks that i can just take out in the rear so i dont really need a kit for the rear just need one for the front i was thinking 3 inch drop spindles
fdugn545   +1y
Isn't It generally the same as the 01 Rangers? Take a look and see. I could be wrong but...
Sent from GS2 on Tapatalk
baha   +1y
DJM has some kits for you to check out. Check out modplant.com they carry DJM kits.
I'm assuming you are from the US if so, your suspension is the same as the Rangers. Got any pics? I can give you a better answer if I knew exactly what your truck was like.
01/b3k   +1y
i cant get you pics today, thanks for the help ill check them out. its got a factory 2'' lift block in the rear that i could take out and get a 2'' drop but i just need a kit for the front but i don't want the alignment out of whack or i don't want to premature ball joint wear or uneven tread wear
baha   +1y
Oh ok you might have different suspension than the standard type. The Ranger Edge came with torsion bars and I believe had a lift block in the rear so I'm wondering if yours is the same.
01/b3k   +1y
yeah mine has the torsion bars
