Mazda Lowering Static \  going lower. help needed
views 827
replies 5
reed_bryant   +1y
right now, my truck is already pretty low but i wanna go lower. Only problem is, i think my rims will hit the bed sides. Anyone else running the same eskies that i have that are tuckin rim? If so how?
baha   +1y
Nice truck, some switch to 4x4 sheet metal but it would probably be easier to get a separate axle narrowed and swap it in. Another option is rolling the inner lip.
reed_bryant   +1y
i was thinking about pulling the bed sides or flaring out the fenders but idk how to go about that
baha   +1y
I think it's kinda ugly to.
low_life77   +1y
I would go the route of flaring your bed sides being yours looks to be painted and the 4x4 beds are becoming harder and harder to find. It's fairly easy to do this and I will also be doing this for when I put on my shorter rear end with wider tires. Anyways here is a thread posted on here and at the bottom of his post is the link to the minitruckin write up and gives you detailed step by step directions with pictures. Doing it this way you can easily get between 1-3 inches of flair on each side. Hope this helps bro.
reed_bryant   +1y
thanks a lot man !
