Sway bar experience needed
dillon8495@live.com's avatar
missed.a.leter's avatar
missed.a.leter
So i will be installing a sway bar on my 89 and i started thinking of when to weld the brackets on for the bushings. Would i want to lift the rear end to get the weight off of it then mark to weld? Or would i want to keep the weight of the truck on it then mark to weld?
I figured leave it on the ground? but i wanted some experienced help cause the axle does move alittle in suspension articulation.
sincitylocal's avatar
sincitylocal
When the truck is at ride height, the sway bar arms(the part that attaches to the end link bushings) should be level.
missed.a.leter
Okay so it dosent matter if i do it on the ground or lifted. Just as long as its level?
missed.a.leter
*at ride height
sincitylocal
Yes.
Be cautious... Tack weld, then check before final welding.
missed.a.leter
Haha yes i know. I work at a fabrication shop as a fabricator apprentice/welder. Pretty experienced with mig/brazing/arc/plasma cutting. Not so much tig but im workin on it!
missed.a.leter
And i was excited to be welding this on but figured out its bolt on..... Lol
