Mazda Exterior \  offset
offset
Mazda Exterior Mazda Tech
views 1029
replies 4
following 2
schreff   +1y
Does anyone know what are offset is? I want these 22in momo's I sell. There 22x9.5 with a 15mm offset. There 6x5.5 lug pattern. Im hoping these will tuck. I dont care about cutting shit cause its going to be body droped....im thinkin 2 or 2.5 inches. The wheels are only $1700 so I gatta have them. They usually sell for $1100 apeace.
whatisit   +1y
They aren't going to tuck. You usually have to get a wheel with a front wheel drive offset, which is usually 39mm - 45mm, to tuck with no problems, and that normally is a 7"-8" wide wheel. You're talking 9.5" wide wheel with only 19mm offset, sorry don't see it happening.
schreff   +1y
Ahh ok. Check this out though, there for the Escalade. There acully a 20mm offset.
APPLICATION WHEELS, 2004, CADILLAC, ESCALADE, SPECIAL FIT DATA, FOUR WHEEL DRIVE 6 X 5.5 HUB CENTRC GM TRK, 22 X 9.5
CENTER CAP N/A
LOAD RATING N/A
BACK SPACING 6.04 INCHES
BOLT CIRCLE 6 X 5.5 HUB CENTRC GM TRK
CALIPER CLEARANCE N/A
LUG STYLE TUNER LUG CONICAL SEAT
OFFSET 20MM, .787 INCHES
MAX TIRE SIZE N/A
schreff   +1y
Or how bout these 20x8.5's?
APPLICATION WHEELS, 2004, CADILLAC, ESCALADE, SPECIAL FIT DATA, FOUR WHEEL DRIVE 6 X 5.5 HUB CENTRC GM TRK, 20 X 8.5
CENTER CAP N/A
LOAD RATING N/A
BACK SPACING 5.81 INCHES
OFFSET 27MM, 1.06 INCHES
MAX TIRE SIZE N/A
whatisit   +1y
Its going to have to be at least a 39mm-45mm offset to tuck. For a 8.5" wheel it'd have to be more like 50-55mm.
