UH-oh... i screwed up..haha
miked
well i got my tail light fillers from grant an went right to work.. shaved the first one..had a buddy line up one end while i did the other one n tacked it in place... 4 hours later.. i realize that i seem to have lined it up wrong.. the rear is off by roughly 1cm.. so the top bodyline looks like an s10's haha.
now.. here is my question..
can i just take my cut off wheel to it an cut it out an tack on "fillers" to lengthen the areas that need to be?
on a side note.. the other side looks sick.. an yes i know... worthless without pictures... but it was either a new digicam.. or truck parts...
i believe i picked the right choice.
miked
since i need to bump up my posts.. my digi cam has enough power some how to take one picture an then die.
i dont know if u can see it from this picture but here it goes..
mazm's avatar
mazm
its gonna look badass when you get done with it
baggedb22
Looks good so far! Keep it up bro..
madmazda
Its Hard to see Miked, But you should be able to cutter and re-tack it. Keep us updated
miked
well last night i built a filler for the piece that can be seen when the tailgate is closed an tonight... i plan on taking the cut off wheel to the pass side n redo it... the rollpan i still dont see how it goes on.. the bottom curves do not line up at all.
grantkustoms's avatar
grantkustoms
has your bed ever been hit??
miked
not that i was know of. i got it fixed tho.. i just kept hittin the bottom lip on the bed.. until it didnt exist anymore.. it was more then then just usin a cut off disc.
