Mazda Exterior \  phantom grill
phantom grill
Mazda Exterior Mazda Tech
views 1180
replies 5
ed_jr7   +1y
i'm buying a phantom grill for my '91 b2200 how hard is it to intall and what does it take??????
madmazda   +1y
Buy it and Learn from you mistakes, its just an insert i believe. lol
nytrdr24   +1y
U HAVE TO CUT OUT AROUND THE HEAD LITES IN THE RAD. SUPPORT, AND RECESS THE HEAD LIGHTS BACK @ 2"-3", & IF IT IS JUST THE GRILLE INSERT, THEN YOU WILL HAVE TO CUT THE CENTER OUT OF YOUR GRILLE SHELL. IF IT'S THE GRILLE & SHELL THEN YOU JUST BOLT IT IN. IF DOING THE CUTTING OF THE SHELL, PUT MASKING TAPE WHERE YOU ARE GOING TO CUT SO IT MAKES A CLEAN CUT (ESP. ON A CHROME GRILLE), AND USE A COPEING SAW (SAW USED FOR CUTTING CROWN MOLDING, CHAIR RAIL, BASE BOARD) TO DO THE CUTS WITH, THERE IS PROBABLY SOMETHING BETTER TO DO THIS WITH, BUT IT WORKED FINE WHEN I CUT THE GRILLE ON MY OLD '02 DODGE RAM QUAD CAB & PUT THE SOLID BILLET CENTER IN.
JUST SOME POINTERS..
low87dawg   +1y
how much are those grills?
ed_jr7   +1y
just the grill is 180
low87dawg   +1y
that shit is expensive
