shavin with fiberglass
run4money864@yahoo.com's avatar
madbagger's avatar
madbagger
is it ok to shave small stuff like emblem holes and the holw left by the antenna with fiberglass cloth and resin how will it be different if it were done in metal?
drpdmazda
metal will hold up longer and less likely to crack out, i would recomend getting the holes welded or you run the risk of problems later on down the road
impulse's avatar
impulse
weld that shit up.
delawaredime's avatar
delawaredime
weld it, if you use that shit... and water gets behind it or somthing it just turn to shit.. the kid i got my truck from used bondo to shave the emblems.. i hit the fender and the shit just cracked and fell off...
sprkndawg
Weld it all noooooooo fiberglass
phatkix's avatar
phatkix
what they all said,
any bodyshop could easily do it for next to nothing, my buddy got his antenna hole, badge holes and gas tank filler welded in his car for 45 bux canadian
dragorbust's avatar
dragorbust
yeah MOS DEF weld it up its hard enough to keep stuff from crackin out w/freakin metal. i got a fullskin/rollpan combo on the back of mine and it is a BEEEOTTCH. i had to reinforce the crap out of it just to keep the welds from poppin loose.
foesicks's avatar
foesicks
I would have to disagree with everyone else. I think you should weld it
