caddy light whoas
caddy light whoas
miked
so um.. heres the problem. my caddy lights are all wiring n sexy looking. but my turn is very weak n flashes very fast... like to fast.. i believe this is because 1- my battery is low an 2- i have no other lights on the truck ATM ...
or do i need something else?
baggedb22
Mine flashed fast when i had no other lights on mine too!
midnightmike's avatar
midnightmike
the fast flashing is the lack of bulbs up front, and the weak part im not sure, if u conected the signal to the little bulb in the caddy light that might be a problem, u might have to change up some wiring again, but like i told u i have a couple solutions to make the light work just like they did on the caddy
drpdmazda
yeah they are flashing fast because your fronts arent wired up right now, as soon as you hook them up the fast flashing will stop, as far as them weak, if your battery is low they will appear weak,
