what rims fit our trucks?
2blue
what rims fit our trucks? whats the bolt pattern?
grantkustoms's avatar
grantkustoms
chevy F/S fits 6 lug , there are alot of different stock wheels that fit. Almost every 6 lug
nytrdr24's avatar
nytrdr24
6 x 5.5" or if you prefer metric 6 x 139.7 mm
thetornado's avatar
thetornado
also theres the dimension on the middle of the hab that must fit over the mazda hub. most chevys you must get bored out, or have to grind down those tabs down.
midnightmike's avatar
midnightmike
3.75" is the center hub size, nissans are 3.95" GM's are 3.25"
minitruckinvet
all 6 lugs will fit EXCEPT Dodge Dakotas/Vipers/Durangos....Gm wheels have to be bored out in the center..Escalades,Z71's and such. Pathfinder wheels..Toyota 4x4 wheels....Isuzu wheels. Grinding the tabs off of the hubs and brake drums...I do not think is a good idea....they are there to ack as centering devices for the wheels when mounting them and they are also weights to balance the rotor hubs and rear drums.
mazdizzle
Ford and lincoln 6 lug rims will fit too with some minor work. You still have to have the centers machined. I just bought some 18 inch navi's and the bolt pattern it 6x135 where as the mazda is 6x139. They will bolt up I had one of mine on there the other day but the studs sit toward the outside edges of the holes. I don't see it being a problem but I'll find out when I get them back form the machine shop.,
baggedb22
MTV, your somewhat right i have cut the tabs off my wheels the reason everyone says not to do it is b/c the tabs are there on the mazda wheels b/c they are hub centric but the Gm wheels are lug centric, if u get bludge style Gm lug nuts to put the gm wheels on a mazda therefor converting it all to lug centric instead of hub centric, I never had a problem with mine and there is no wobble or anything at all...
johnh2os
So I should be fine with the Avalanche rims(17's) that I just picked up for $100 then(after being bored out)????
minitruckinvet
BaggedB22....good point..never thought of that.
John......Lanche wheels should fit good after you bore them. I also got the Gm lugnuts from a blazer or Astro (cannot remember) so that it had acorn nuts on it. Stock lugs will dig into the aluminum because they do not have a wide enough base.
