How to remove bed??
How to remove bed??
mpenner49
I need to remove my bed to do some frame repair. anyone know how many bolts hold on this bed, if there are any hidden bolts or if I will run into any problems or anything?
2fine89's avatar
2fine89
Nothing hidden - 6 Bolts on an cab plus. (May be 8 on a reg. cab can't remember)Pull the tail lights out and feed the wiring down the access holes and remove wire from retaining clips on the bed. remove (may have to cut) liscence plate light wires behind the plate pan. Don't forget your fuel tank filler neck - 4 bolts behind the fuel door, and your remote release cable ( if equipped - will also have clips attatched to bed.) OH YA if you still have a bumper it would be easier to remove the bed with the bumper gone first. 2 bolts on each side.
BC
blue crush
^^^ that about sums it up............
2fine89's avatar
2fine89
LOL ya fresh in memory - just did it on friday.
lukeinva
yeah hit it on the head only other thing you may need a friend to help you lift it off.
2fine89's avatar
2fine89
HAHA yup I forgot that part cuz I just heaved mine off the back - puttin a 4X4 bed on so I wasn't too worried about scratching it.
