5 lug convertion
5 lug convertion
lucky13
anyone have pics or a write up on converting to a 5 lug, because then i will have more wheel choices, and also what i would need.
thanks
lukeinva
just get them redrilled it would be easier. or you can get a yota rear end. For the front I heard you can use astro van hubs I believe not 100%.
slammedmini469
its Aerostar hubs.....
roach25681
You cant just swap the Mazda hubs out for the Aerostars. There is some fabrication involved.
Toyota parts all around or redrill.
slammedmini469
what kind of fab?
lukeinva
yeah thats it!!
I knew it was some kind of ford van!
madbagger's avatar
madbagger
about how much do u think it would cost to have your rotors drums and hubs redrilled to five lug?
nate's avatar
nate
has anyone done the aerostar conversion??? getting ready to do this on a 2600 mazda.. as I understood it you just swap the hubs I was told the same bearings and everything.. any info would be apreciated.. thanks
blastation
so if i redrilled my hub to 5 lug wouldnt that make the hub weeker, can someone show a picture of a redrilled hub so we can get a idea.
roach25681
From information on the web. Yes you can make it work. The bearings are NOT the same size and you will need custom bearings for it to work right. And you have to cut the caliper or caliper bracket somehow. You'd probably come out cheaper by having them redrilled. I think you have have the fronts done for around $200 or less? Id assume the same for the rear.
Blast, when you have your hubs redrilled, the existing holes are plug welded up and new holes are drilled. So no, it would not make them weaker.
