need help lights arent working
loweredintensions@excite.com's avatar
projekt94 (david)'s avatar
projekt94 (david)
sup guys like the title says my brake lights do not work. when i press the brakes they dont flash. could it be that that i need a new flasher ,though my turn sigs work. could it be the wiring? a fuse? i dont know any help or suggestions would be greatly appreciated, thanx
maz
It won't be a flasher as those are for signals only. Check your switch and bulbs also along with the other things. THe switch will be down on the brake pedal
projekt94 (david)
are all mazdas the same cuz ive got a 94 model.
2I
2 intense
make sure that all of the fuses in the panel inside of the truck are good. if they are give it about a day and recheck them and you shoul find the problem. if not hit me up cause my truck did the same shit.
pont's avatar
pont
86 to 93 are differnt then the 94 and up the 94 and up are just like the Ranger
projekt94 (david)
yeah thats why i was asking cuz as far as i know im the only one here with a 94+ madel.
