Drilling Rims
miniwatt@bellsouth.net's avatar
Drilling Rims
watt's avatar
watt
im neew to the bscene and i noticed some of you guys talking about drilling rims. what exactly are you drilling and why? i figured its good information to know.
lost_b2200
To put full size chevy wheels or Escalade wheels on your mazda the center hub hole has to be enlarged. The lug holes are exactly right though.
watt's avatar
watt
you do that all the way around?
thetornado's avatar
thetornado
you bore out just the center of the hub. the big hole in the middle of the rim. that needs to be bigger to fit on the mazda hub.
so yes, you "do that" all the way around being that a circle must be bored all the way around for it to be a circle... hah
joshbrennan
and if you meant all the way around as in all four wheels, then yes as well.
watt's avatar
watt
i meant all four wheels when i said all they way around. im would be severly retarded if i meant the actual hole.
