BACK GLASS
BACK GLASS
carolinasled
I JUST SCORED A SOLID BACKGLASS FROM A FRIEND, AND I HAVE SEARCHED TRYIN TO FIND OUT HOW TO REMOVE THE SLIDING BACK WINDOW. DO I NEED TO HAVE A FRIEND IN THE BED HOLDING THE WINDOW? AND ALSO DO I NEED TO WORK MY WAY FROM THE INSIDE OF THE CAB TO THE OUTSIDE? AND ONE MORE. DO I NEED ANYTYPE OF CAULKING OR SEALENT??? THANKS GUYS ANY HELP WOULD BE GLADLY APPRRECIATTED
THANKS RYAN
drpdmazda
the window gasket is all you need, no caulk or sealent etc. its better to do it on a hot day or heat up the seal a little bit with a heat gun so its softer and easier to work with, i just start at the top corner on the inside and push on it gently until it starts to work itself out, its a pretty easy thing to do really
good luck
watt's avatar
watt
I have been thinking of swapping it out too but i have no clue where to start..see if you can get some pictures..?
carolinasled
thanks drpdmazda. so when i put the solid in do i use the old string trick???
appreciatte it, thanks ryan
pont's avatar
pont
yea that will work use a little soap to
carolinasled
ok thanks guys alot..... i'm goin to do it tommorrow night i hope if the wife doesnt want to go to the riverdogs game....
drpdmazda
yeah def string and soap, and like someone else mentioned try to take some pics if you can so it can maybe be posted as a help to other members
good luck man
fanninator's avatar
fanninator
i guess he went to the riverdogs game. -bf
