Door?
Door?
rob
I would like to shave my door handles and have kit where i can open my doors with the push of a button. I want it to be secure though cause i have a system. so if anyone could please inform me on what i should get and how hard it is to install that would be great.. I have an 86 b2000
Rob
sierrax
AutoLoc is the best for what you want. They make fairly good instructions so if you can install a stereo, then you can most likely put a shaved system in.
drpdmazda
autoloc also makes an emergency release cable that you may want to pick up, if your battery dies and your handles are shaved you either have to take out your back window if you can, or you are pretty much shit out of luck, with there emergency release cable, you wire it up to the door handle inside and hide a little know somewhere you can easily access, that way if your battery dies you can just pull the cable and it will open your door
valiant's avatar
valiant
some guys put a hood release on the outside of thier truck to pop the hood and put the emergency release under the hood. so if someone happens to find the release on the outside, all they did was open the hood. it discourages some people cuase they dont want to look all around your engine bay for an emergency release.
-Mike
