taillight problem..........
carolinasled
ok i'll tell you guys all the symptoms,
when i switch my lights on my brake lights stay on constant. they dont dim to taillights like they should.
but when the lights are switched off, like during the day, the taillights work fine....
what could this be....
i've checked my grounds, i've checked my light bulbs.....
could the light bulbs be in the socket backwards???
dont know i just dont want chancing a ticket at nite....
maztang (ryan)'s avatar
maztang (ryan)
sounds like the brake light switch going bad.
bagdb2200
It sounds like the bulbs are in backwards. Take the socket out of the tail light housing and see which filament lights up when you turn your headlights on. The smaller should be lighting up. If the bigger one is then you know it's in backwards.
rutter0907
need to check to make sure you have right bulb in that socket
madmazda
Check the bulbs first...did you recently just change them?
madzatruck's avatar
madzatruck
Do you have trailer lights on the truck? I've had one that did problems like that when the wires wore out and were touching.
carolinasled
i changed out the bulbs like 2 months ago, so i havent had time to checkem out lately been busy but next off dy will be tuesday so, i'll check it outthen.....
