ok so i just got done baggin my truck but now my tail lights keep blowing fuses. the wiring in the back isnt touching the ground, no other fuses are blown, that ground in the back is on and good. i have no clue what it could be. has anyone else had this problem after baggin.
drpdmazda
make sure that somewhere along the line you didnt melt the wire harness when you were welding, when i had the wheel tubs put in my truck my turn signals stoped working, i couldnt figure it out for a while, then when i started tracing the problem i figured out which signal was the actual problem then checked the wires, turns out they melted the wires when they were welding in the tubs, try taking one bulb out at a time and checking if the fuse blows, if it blows with only one bulb in and not the other at least you know the problem is with that light
good luck
hocbj23
Wiring harness for the electrics in the rear of the truck exits out the back of the cab,low down on the passenger side.Be sure u did not pinch a wire when putting ur bags in. BJ
gravity5
take the taillight bulb out and put a new fuse in....then turn on the lights...if the fuse still blows then you have a grounded wire somewhere between the switch and the taillight socket...
