making Z71's fit
making Z71's fit
1990b26akathebeast
ok so i just bought i set of Z71's from slamditbig (good seller by the way) and im wondering what exactly do i have to do to be able to bolt them on? there not bored and i dont plan on boreing them so im suposed to grind something on the hub right??? pics would be GREATLY appreciated. -thanks
robbie
if your not boring them you'll have to grind the tabs off the rotors upfront and grind the hub off the rotors on the rearend. You'll also need to get some bulge acorn lug nuts.
slmdiam
Alright man all you have to do is grind down the little nubs on the front and back hubs. When yu take your wheel off of the front you should see I think or small little nubs coming off of the hub near the studs... Just take a grinder ans grind them down as smooth as possible till they are all gone that will allow your wheels to but up against the hub like they should. The fronts are smaller than the backs, but you need to do this on all of the wheels... You will see what I'm talking about when you pull your wheels off. You have to get them all smooth essentially not ther so that the wheel will sit on there evenly and doesn't woble. Sorry no pics, but pretty self explanatory.
slamditbig's avatar
slamditbig
same thing he said man.
immortal1 (linn)'s avatar
immortal1 (linn)
Just a suggestion.... remove the lug nut studs before grinding. Doesn't matter how careful you are, you will end up nicking a few. Usually, you can put a lug nut on until its flush with the end of the stud, then tap them thru with a hammer.
crazymikey's avatar
crazymikey
or if you're careless you might just have yourself a 4 or 5 lug conversion,lol.
F
five
lol , that would be a cheaper route to go wouldn't it , just grind them dam things off lol.
