xtera rims
twistedsmily@comcast.net's avatar
xtera rims
twistedsmily's avatar
twistedsmily
has any body tryed putting eterra rims on a mazda b doe any body know if they will fit I've seen them on a hardbody but havent seen them on a mazda I think they would look dope
valiant's avatar
valiant
Bolt Pattern: 6X139.7 ----Yes the bolt pattern is correct
Lug Size: 12mmX1.25 ----The Lug Size is corrent
Center Bore: 100 ----Need to have the center bored out to 108 or shave your hubs down a little.
so yes, with a little work, they will fit.
-Mike
schardbody
what wheel are those specs for?? until 05 all nissan xterra, frontier, and pathfinders had 108mm bore.
joshbrennan
well whats the offset on these?
that's the big question. well if you are bagged at least.
valiant's avatar
valiant
this is what I have been using,
it says 2000 and on
-Mike
slammed83mazda's avatar
slammed83mazda
18x8
Chrome 6 on 135mm
Acorn +40 mm
would this fit?
joshbrennan
the 6 on 135mm is wrong. the mazda bolt pattern is 6X139.7, you would need to do a re-drill.
a basic rule for mazdas is a +45 for an 8" wide wheel; +40 is only about 3/16" off, so the offset should be fine. This rule is for 86-93 mazdas, so im not sure about your 83, but i'm sure they are close.
schardbody
valiant that site has all the nissan bores wrong. 3.95" is the center bore for every nissan pickup up to 04.
twistedsmily
so they will fit thanks guys
