chrome 17'' wheels and tires off 05 chevy crew cab,265x70x17
down2earthdawg
They miht I would go with a smaller tire size like a 215/45/17
devb22
I second that motion!
A smaller tire size would save you time/money in the long run, and make those wheels look bigger!
A lower series tire would be a good investment!
I do agree though they should fit, but I would test fit one rim on both front/back if you can!
Good luck!
Dev
schardbody
you will have to bore the center of the wheels out or grind down the hub and rear axle tabs. and DEFINATELY get smaller tires. those tires are way to big.
